Online: Stuart
Rim Dimensions
  • Gware
    Gware
    Gday blokes,
    Im going to replace my front rim on my bike. Its a 1998 FXSTC. What is the wire rim size ?
    2.15 or 3 ? it has a 90 x 90 x 21 on it at the moment.
    Thanks.
  • Gnoo
    Gnoo
  • Gware
    Gware
    Thanks mate
  • Far Canal
    Far Canal
    Do you want to run the "pizza cutter" 90mm front tyre or go for something a bit wider?
  • Gware
    Gware
    I'm keen to keep the same size.  I'm thinking a fat spoke rim
    and new rotor with performance machine caliper. I was told I'll
    have to machine down the wheel spacers due to new rim has sealed bearings.
