Wiring Harness
    Did you put in the RIGHT battery? Just because it fits doesn't make it right - usually its the CR2032 one I think.
    So I presume you checked it was up the right way too... Then I'd check the battery with a multimeter (not the first time a "new" battery has been flat). After that place the FOB on the seat (minimise chance of interference) before trying again.
    The fact that the PIN failst doesn't make sense, unless you don't actually know the PIN and you're putting in some PIN you read online.
    Well you wouldn't be the first to put the battery upside down if you did. Only thing I can think of is a trip to the dealers...and I'm betting that will be a bend over and lube up experience.
    Fuck there are some real tools on this forum. One fucken question fucken wonders. Fuck off and ask your dumb fucken questions elsewhere then ya retard knuckle draggin fuckwit.
    Someone genuinely tries to help a newby that doesn't have a clue, and then they abuse them for there efforts! WTF no fucken wonder I hesitate sometimes on answering these oxygen thieves.
    Note to all newbies, If ya need help, ask a genuine question and say please, thankyou, and intro-fucken-duce yourself first so we can qualify you first to see if your a fuckwit and if you are sensible and genuine you will get shitloads of fucken help! If you are a retarded one question wonder whos only mission is to ask a dumb question that you can ask a dealer in 30 seconds over the fucken phone, then FUCK OFF with your shit. FUCK!
    OK lads now I need a lay down and a Bex!
  • markwoumla
    markwoumla
    Hey, Hutchy,, I'd be helping the Bex down with a few nice JD's ,, that should do the trick .... I hope to fuck he does'nt have a orange bike !!!!!
  • The Bobster
    The Bobster
    Here is something that may answer your question try and source an early 2000 harness when fuel injection started.
  • chopa
    chopa
    Buy a fucken lighter and burn the fucker
    Cheers FLHuTChU, a good laugh in an otherwise fucked up year.
