Book of bling
  • jim76
    jim76
    Gday was just having a read of last years book of bling( i think its this years the 105th year). on page 131 picture L there is a chorme cap for the steering stem bolt in the pic there is a bolt with a hole in it my question is could this be a way of pumping grease into head stem bearings? i have never had the head stem apart before n dont now if the bolt would work any ideas?
  • jim76
    jim76
    Thanks for the info that link is the pic i was looking at in the book alby thanks, i forgot about putting this up(must remind self to click the email thing when i post) it was a guess would be a good idea if u could put a grease nipple in there. i have never had one apart so unsure if u could do it, u would have to pump a fair bit of grease in to get to bottom bearing.
  • jim76
    jim76
    thanks RT, so would have to do what u did on your dyna then with the grease nipple on the side of the frame.
