Front end wobble when at speed, with apes
  • dv8
    dv8
    Hi, I have a 2010 softail, 16" apes, doing 140k's it's fine, but go to 150-160 and it gets a real bad front end wobble, Go any higher and it's a death trap. A mate took it for a ride, he weights about 160-170 kg's, he had bike flat out and no wobble. I am 115kgs. would changing to a heavier spring rate in the front end help, or are there any other things I can do to stop it or at least resduce this. Want to keep apes, love them. cheers for any suggestions.
  • dv8
    dv8
    cheers, food for thought.
  • Spook
    Spook
    Loose headstem bearings?
  • the_mongrel
    the_mongrel
    And tyre pressures. They will add to the wobble, especially the rear.
  • Wimbo
    Wimbo
    If you have air going up one Jean leg at high speed, that might cause a problem as your pulling the bike over to one side.
    Be care for that, otherwise it could be any of the above.
