Online: Aiwoz65
turbo knowledge tc
  • jrcperformancefxdb
    jrcperformancefxdb
    hi was wanting to touch base with anyone on there turbo setups mainly at the point where im getting ready for tuning im a hands on person and want to do it all myself for my own satisfaction any ones input would be really apreciated
  • nhb006
    nhb006
    What management you planning on running?
    I ran the race tuner for off boost mapping and a PC 5 for on boost mapping. Set up & tune done by Neville Lush.
    jrcperformancefxdb
    how much power is ur bike making what boost it looks really good ur setup i have the thundermax on it although it crapped itself and is on its way back to the states hopfully il get it back iv fitted 3 bar map sensor  and wide band af gauge i tuned the bike with tmax after i fitted 106 kit and cam they are fairly easy to tune 2d maps for fuel and timing i started with one of there tunes and tweaked it im a bit anti social in person and im not sure on the local tuners up here if u could call them that so i like to learn how to do it myself i mean u dont need to be a doctor to tune a bike
  • dynoharley
    dynoharley
    jrcperformancefxdb
    dynoharley turbo setup looks real nice im running 3 inch dump pipe on mine dont like the sound it makes  smaller pipe does it sound better what ecm are u using
  • dynoharley
    dynoharley
    the pipe bottom is now turned out slighty at bottom with chrome heat shield on it , came up neat , tuner is pc -5  this eng has mild cam only , stock 103  with 5 pound boost  ,went 145 rwhp at 6100 , limiter stopping it ,can put more boost in to it but standard harley cranks flex like crazy , owner more than happy with it
    jrcperformancefxdb
    was the pc5 easy to tune with i have 7 psi waste gate on mine i have the tmax with 3bar map only thing is it crapped itself after i installed turbo was removed while fabrication was being done what injectors are you using mate i have andrews 54h cam in mine cant beleive the power from ur turbo setup thats awesome hope mine makes around the same thanks for ur info any help you can give me would be priceless thank you again
