thunder max just stopped working
  • jrcperformancefxdb
    jrcperformancefxdb
    plugged tmax back in after turbo install and i dont have power to the starter or speedo and i cant link to tmax now has anyone had this happen been over all wiring funny thing is when original ecm is plugged back in everything runs normal t max support wants me to send it back just worried it will get lost in transit over usa just want to try every avenue befor i post it any help would really be apreciated thanks
  • Retroman
    I've removed a couple of Thundermax units over the years and replaced the stock ECM and then used older SERT and then TTS to tune the stock ECM.Just as good power and BETTER fuel consumption to boot !
    The Thundermax units did seem to be electrically weak and prone to water incursion and subsequent corrosion.
    This was on 2007 Bikes which are now fairly "old" of course. Problems just like yours , no power continuity , no speedo etc etc
    How old is your bike , and where in Australia are you ?
    jrcperformancefxdb
    the bikes a 2012 fxdb it got about 7500km 6500 with thunder max im in north qld humidity but bike is always garaged ridden once in the rain so have you seen the tmax lose power befor iv had a hard time trying to get through to tech support on issue they reckon it was my bike finally got them to take it back and have a sus
  • Blue Dog
    Blue Dog
    I have put in the Thundermax unit a couple of years ago. Happy as with the results. One bad part of the change was that I had to buy another speedometer/tachomter/ main unit as they just did not talk to each other. Lost a few thousand Km on the clock. All is good with the new combination gauges now. Now one either from this site or from Thundermax could answer the question why the two units did not update together. I have the after market Harley speedo/Tacho unit. Dont know if it effects the standard speedo unit the that is stock.
    jrcperformancefxdb
    i was able to sync mine i cant fault tmax apart from issue i have now it means alot to be able to work on my own bike and not need a dyno tune as i like to run with my own ideas how to modify my bike not a dealership. saying that they are great people the harley mob
    jrcperformancefxdb
    iv had some good news thundermax have fixed issue have not told me what was wrong with it but im stoked to be getting it back and did not take that long once they got it
    jrcperformancefxdb
