07 roadking no go
  • grim
    grim
    hey guys need some advice, got all the gear on last week loaded the bike up, mates arrive all set to go, my fn ride wont start, good as gold the week before. bike turns over well, got a good biff off the leads, when i pulled the plugs they were stone dry after a fair amount of cranking,no fuel getting in im thinking. fuel tank is half full, when i thumb the switch it still gives that characteristic whine of the fuel pump before hitting the starter. It was like a switch has been turned off, does anyone have any ideas before i start pulling my tank apart, cheers Grim
  • cm364352
    cm364352
    Could be the quick connect fitting at the tank.
    Try pushing up on it or twist it back and forth a few times
    that usualy frees them up, if that dont work maybe crank sensor..
    Waz..
  • cm364352
    cm364352
    Ya probly right ,since he mentions he got a kick from the leads.
