Online: beaglebasher, FONTANA302
Night Dragons
  • Steve L
    Steve L
    had a set of Pirelli Night Dragons fitted on Saturday, plus right angle valve stems. Rode home in the rain and had lots more grip even being new tyres. I went for a ride today and these are really nice in the twisties. They make the bike feel so much lighter and also make it tip in easier, very happy with them. :)
  • markwoumla
    markwoumla
    Hi Steve,, I take it you have stock wheels on your ride, So, I also take it you replaced your stock Dunlops with the Pirelli Night Dragons .. Could you post up the Night Dragons tyre numbers , (front and rear), so I can do a search on google.. The tires you fitted to your 2014 Street Glide should fit touring models from 2009 ,(start of the 180 rear), to present.. It's just for info purposes , (it can get a bit confusing ), on what other brand options , will fit the touring range, (2009 up to present), other than Dunlop. Good to hear your happy with the Pirelli Night Dragons ... Cheers ..
    Stock tyres 2014/15 Street Glide .    Front 130/60/19 61H     Rear 180/65/16 81H .
  • Steve L
    Steve L
    Yeah what Tim said except for the front I had to go with 120/70/19
  • Steve L
    Steve L
    yeah but the overall dimensions are only slightly different, she tips in easier other than that cant really feel any other difference.
  • Bucky15
    Bucky15
    JP Cycles have a sale on at the moment for tyres. I have Dunlop American Elites on the fatty and very happy with them. Good k's and good grip. Everything I have read also states other riders happy.
    http://www.jpcycles.com/2012-harley-davidson-touring-street-glide-flhx/tires/dunlop
    Give that a look. Even with the $ now they are still pretty good value.
    Cheers. Bucky
