Springers
  • Vic
    Vic
    So i've never ridden a springer but am thinking of having a look at one.
    2001 model, do they handle as badly as some suggest?
    Havn't owned a HD for a while but looking at owning one again.
    My last was an old evo softail nostalgia which was pretty ordinary in the handling department,
    Would the springer be worse?
  • Filthy
    Filthy
    I have had this for about 7 years/50000km:
    although at the moment her future is uncertain after a spill :
    So  I've bought in a replacement :
    And I can tell you technically :
    Springers have more vertical travel than telescopic forks
    They have a "constant rate"spring to them
    they are more "rigid"thank telescopic forks and suffer less flex
    They are howeve heavier, more expensive and when maintenance is required, there is more of it,
    Having said that, the '05 has 70,000km on it and the front end is still fine - bearings and bushes have no wear. Don't believe all the naysayers.
    "Seat of the pants"- I love them and reckon they are a superior front end.
    My 2 Bob's worth
    Philthy
  • blueystar
    blueystar
    have 2 of them and love it
  • Vic
    Vic
    Thanks fellas, nice rides!
    They can't be that bad if the both of you have 2.
    Damage doesn't look too bad Filthy.
  • nhb006
    nhb006
    Mine handles well for what it is.
  • TJU
    TJU
    Can only speak of my own experience but my 99 Springer Definitly out handles my 08 FXSTC ... of course there ane many variables but as mentioned above by others they are a heavier front end for sure but i am pretty sure if you do a little history research on them you will read articals that state how much better they are than standard telescopic front ends , the main reason for change was the weight considerations .
    I do get a slight buzz through the bars on mine but the main reason for that was because i changed out the top tripple tree to one that excepted normal handle bar risers which gave me a far wider choice of handle bar to choose from ... by doing that though it ment my risers are solid metal to metal with the tripple tree and i don`t have the same rubber vibration isolaters that most people have ... a couple of bar end weights and some foam handle bar grips have taken care of that issue for the most part though .
  • TJU
    TJU
    nhb006 ... man that's still a sweet looking ride .
  • nhb006
    nhb006
    Thanks TJU
  • Ricca
    Ricca
    Nice bike bud whats rear fendor is that ? looks tough
  • mutley
    mutley
    picked her up yesterday 27\2\2015
    today
  • nhb006
    nhb006
    The rear fender is a custom jobbie - 250 struts, 11 blank fender and a lot of metal work to make the seat fit.
  • Vic
    Vic
    Well It's been a while since I posted for info on the springers.
    But finally picked one up last week.
  • Retroman
    A 2007 FXSTSSE if I am not mistaken ! In Abyss blue/Blue pearl. ( I'm a bit of a Springer fan meself !)
    Is it an "original" Aussie one or a more recent grey import ?
    Where in Australia are you ?
  • Filthy
    Filthy
    Nice Bike Vic - congrat's mate.
    I am sure you will enjoy it !
    Philthy
  • Vic
    Vic
    Cheers Philthy, I'm thinkin I will!
    No your not mistaken Retro,
    was a personal import in 2010, had 2000 miles on it, now has 7500 k's.
    As a side note, I wish I hadn't fucked with the thundermax tuner, but if
    it's there you gotta play with it right?
    I now have a bit of reading / research to do.
  • ralphski
    ralphski
    nice ride...
    i love the front end, very smooth.
    struggles when pushed really hard.
    got the same one as retro
  • Vic
    Vic
    Cheer's Ralph, I gave it a bit of a push this morning through the hills
    and she handles great, a big improvement over the last HD I had for sure.
  • Bilko
    Bilko
    Nice bike Vic, I love the springers and wish I could have kept my crossbones. The '07 CVO's are the pick of the bunch in my eyes. However all softails handle poorly particularly compared to the new touring range. Riding slower fixes that tho.. The biggest issue I had with my springer though was the front brake, absolutely useless.
    I just have to find some more cash to put another springer next to my Street Glide :)
  • TJU
    TJU
    Nice bike Vic .
    Hey Bilko ... try chucking on a 6 pistom PM Caliper ... makes a marked improvement over the original , Lol .
  • ralphski
    ralphski
    hey TJ, looking at PM caliper for my FXSTSSE 2.
    Where did you get your one from? issues ? etc etc.
    Around the $ 600 mark on EvilBay.
    I wonder why HD changed from right side on the '07 SSE, to left side on the '08 SSE 2?
