Removal of old outer primary cover gasket
  • Goodgreaser
    Goodgreaser
    G'day all,
    I have an 88 softail and in the process of replacing my gaskets, seals and bearing on my primery.
    Just wondering if I can get some advice on removing the crusty outer primary gasket that is caked onto my primary case?
    I dont want to use a metal scraper and risk guaging the casing.
    Is there anything I can soak it in to help get a clean surface?
    Greaser
  • Goodgreaser
    Goodgreaser
    Thanks. I'll give it a try!
  • Goodgreaser
    Goodgreaser
    Thanks it looks like a weekend job!
