Oil pressure
  • gbarratt
    gbarratt
    Could anyone help me with an oil pump problem. I have  96 Road King and recently had the oil pump off for a pressure problem. Circlip had come off the pump shaft, and I have replaced gaskets and circlip, but still no pressure. Does the pump need priming? If so, how? I have had it off before with no drama at all. Thanks.
  • Ando
    Ando
    Id double check ya have it back together correctly
    get them rotors around the wrong way and ya won't get any pressure
  • gbarratt
    gbarratt
    It's Ok thanks mate I have discovered the problem. The shaft  had gone too far inwards, dropping the locking key into the gear case, just like it says can happen, in the service manual. Should be reasonably plain sailing to rectify this... Yay!! back on the road soon. That's what it's all about hey?
  • gbarratt
    gbarratt
    While on the subject of locking keys, I am wondering if it matters which way you fit them. I have always put the curved side down into the slot on the shaft, but it occurs to me now that putting the flat side into the shaft slot might make the job easier? Any opinions?
  • HDNUT
    HDNUT
    Rounded side goes into the shaft. The slot is cut by a round tool, so the square edges will probably not go in far enough.
  • gbarratt
    gbarratt
    Thanks HDNUT. Appreciate your reply
