Bar raisers???
  • td42dan
    td42dan
    gday all, i got a 09 super glide custom, std seat n bars, on a long ride i get sore in between the sholder blades, ive been thinking about putting on some
    pull back risers, as i like the std bars, im 171cm tall, just wondering what people are using on there dynas??? pics would be appreciated.... Cheers.
  • costy
    costy
    Hi mate, try going into one of the local dealers, most of them should have a mock up bike which allows you to choose different bars and seat combos to suit you better
  • td42dan
    td42dan
    cheers,
    I put 4" H-D curved risers on my '12 FXDC . Fitted well , didn,t have to change any wiring or cables .
  • td42dan
    td42dan
    were they a HD part or after market???
  • td42dan
    td42dan
    H-D part , 4" curved risers .
  • Spook
    Spook
    Have a look at Flanders bars out of USA. Measurements are on the site. Have them on my Roady. Link following.
    http://www.sideroadcycles.com/ImportedMotorcycles/ImportHandlebars/ImportHandlebars.html
