Do I need this bracket?
  • Mr.Mow
    Mr.Mow
    just took the chrome bell horn off, can this bracket come off too or does it serve some sort of structural purpose?
    Due to the thickness of it I would say it needs to stay on to help support the heads. Keeps them a constant distance so the intake doesn't suck air. Similar job to bracket on the other side.
  • Damage
    Damage
    Flip the bracket over 180 degrees and it wont be as ugly.
  • Up2nogood
    Up2nogood
    Don't believe it's needed. It's that thickness to support the horn and tin cover.
    If you're worried about removing it, have a flat bracket fabbed out of SS plate and powder coat or polish, depending on preference.
  • Up2nogood
    Up2nogood
  • KiwiRob
    KiwiRob
    Can't see any reason to leave that bracket on once you remove the horn. 4 studs/bolts through each cylinder & head should hold things steady I'm sure.
    If it was to hold the heads steady, then it would be straight, rather than have  a "U" shape in the middle. - Rob
  • Daggs
    Daggs
    I would fabricate or machine up something that looked neater and fit it. Its probably not needed but would give a bit more rigidity to the motor
