Bike insurance/exhaust
  • Streetbob06
    Streetbob06
    Can anyone tell me if I have vance n Hines pipes on my bike will that effect my insurance if I was to make a claim? Thanks in advance
  • mickle
    mickle
    Not if you let them know they are fitted to the bike, phone call is all that is needed.
  • berserker
    berserker
    If your not at fault, it doesn't matter at all. You just update details during the claims process. Better to call them and let them know though because if you are at fault or the bike is stolen, it may cause issues or delays
  • FLIPDOG
    FLIPDOG
    last time I insured I listed vance and hines pipes, SE heavy breather, burliegh bars billet front wheel custom seat.
    Didn't affect my premium but will be replaced under claim if anything happened, not to stock standard specs so its best to put those on the policy otherwise if you make a claim they will return your bike to factory compliance
    My telepathic ability tells me he's with Billy Wong's Best Insurance. And Billy Wong doesn't fuck around with such things. Lucky you came on here and had me read your mind rather than relying on advice from a bunch of strangers who have NFI who you're insured with.
  • Streetbob06
    Streetbob06
    Thanks for the replays so far and bonkers I haven't chosen one yet but there all asking about modifications to the bike and I thought I might get caught out if I had to make a claim and the exhaust is for off road use only.
  • Nado
    Nado
    QBE have no problem with (reasonable) modifications. Only issue is if they're not listed they're not covered. Meaning in event of a repair they'd be replaced with stock system rather than what's on it. Have had two seamless claims on modified Harleys over the years with no issues. Also worked for QBE for a while so saw behind the scenes. Would not go anywhere else. Although Shannons is good for really old or extremely custom stuff as they will sometimes do a higher agreed value. For me...QBE all the way.
  • FLIPDOG
    FLIPDOG
    QBE is my insurer also.
    They asked me about any mods and the cost of those mods and I told them.
    All was good
