Online: tussuck, softfat
1986 evo electrical issue
  • JG
    JG
    Hi all, has this happened to anyone here,
     I jump on my bike turn ignition on start it up, I push the break (hand or foot) and the headlight turns on release the leaver and its off, turned the ignition to lights the bike stalled, hit the start button fired up straight away headlight is on but the break light is stuck on as well, WTF is going on,
     main earth is ok even with the engine off or on does the same.  anyone seen this before ?
  • Independant_84
    Independant_84
    Mine died once on me in the dark middle of nowhere when i hit high beam .
    Turned out the high beam wire to the headlight had rubbed through and it took out the breaker and everything else with it.
    Put it on low beam when it reset and sussed it out in the daylight the next day
  • JG
    JG
    far out after racking my brain for 2 days stripping tanks and rear guard strut off and following the wiring loom wire by wire cleaning plugs and connectors i think i found the issue the rear section of the wiring for the tail light was squashed between the strut and frame , everything seems to work normal now i striped and separated the 3 wires. now to find my soldering iron and fingers crossed that's it.
