Online: Wanderer57
USA spec mufflers and exhausts for 07/08/09 Softails
  • Hidiho
    Hidiho
    I bought a set of the U.S. Spec mufflers and there is a remarkable difference in the sound between our Ozzie Mufflers and The U.S. Ones.
    I can't comment on improving the performace at the moment as they have literally just been on, but at least the bike sounds like a Harley now.
    I had my son on the back yesterday and captured what the mufflers sound like before wind was an issue with my camera.
  • fatboboz
    fatboboz
    any of the mufflers with a "big hole" left that suit a fxst 08 ?
    I already have headers and have fixed the flapper valve, but the mufflers sound pretty good, especially if I can drill out the bung that blocks the pipe.
  • fatboboz
    fatboboz
    good news. Thx for quick reply.
    I have my std original pipes off the 08 fxst, so they mufflers should bolt right up to my headers.
    pls confrim cost and how I can get them/contact you?
    I live in Perth also, so shouldnt be a prob.
    Ed - 0404-005-283
    cheers bud
