Online: wildchild, speedzter
Loosing power while riding
  • Coopes
    Coopes
    Hey I've got a fat bob 08 was riding the other day on fwy doing 100 and out of no where it lost power then it kicked back on. Didn't happen again then got to where I was going halfa hour later got back on and was doing 60 when it did it a again went from 60 to 0 to 60  to 0 again a pulled I over let it idel for ten min then took off and it started again up down u down I pulled over and it stopped on me.. Sat there for ten min stated it back up waited and took off. Road for about a hour nothing happed.. Any one out there tell me what's wrong?
    I would go over electricals. Check batt terminals, connections to main fuse, regulator earth etc. Usually always something simples.
  • Darrin
    Darrin
    When it dies, does it seem like it is stuttering, going from full to no power at various intervals? Check your coil leads. Maybe a split leading to arcing and one cylinder not firing. Any rain? Water would facilitate an arc. Otherwise as noted above, go over electricals.
    PS: similar thing to what you describe happened to me one time, in intermittent rain, and it was a split coil lead.
  • Soapbox2627
    Soapbox2627
    change your fuel filter
    cheap
  • Coopes
    Coopes
    Cheers all I cheeked the coil leads just then they seem to be sweet.. And all terminal leads seem fine think I'll put it in for a services and let them find it.. It's due for a 27000k service... Thanks again ... I just wanted to go for a long ride this weekend and know I don't think its a good idea...
