HD hidden Amplified Antena
  • Doc Wilson
    Doc Wilson
    I fitted a  HD Hidden Antena kit to my Glide and it is absolutly terrible hardly any reception at all.
    Had it replaced by the dealer and fitted the new one , Still No good
    I had allready removed the original  antena from the Top Box so I just pluged in the old lead with no antena and got better reception than with the ampliffied one .
    Dont bother they are a piece of junk
    tHANKS FOR THE FEEDBACk, i was looking at one
    This is one mod i was considering also. So thats the question. How many have these H-D units and are they any good? OR are there different brand ones and are they better?
    Bump. Anyone?
  • grahamjb
    grahamjb
    The trouble with these antennas is that they are electrically short and horizontally polarised which makes them perform poorly in an environment where you need a vertically polarised 1/4 wave antenna to get acceptable performance.
    You would be better off fitting a 2 metre coil of wire inside the fairing and use that for your hidden antenna
  • ride511
    ride511
    I have a 2015 streetglide. I followed the instructions from a youtube clip and just slid the antennae up under the seat and to the back of petrol tank. I just zip tied the end to the nearest bracket. I get all radio channels and crystal clear reception.
  • Hallze
    Hallze
    I slid the aerial under the seat on my '08 street glide. It worked a treat. A few months later the radio stopped working and had a "B2017" code. I google that and it says it's the front speakers open circuit. I checked them out and both speakers were fine. More google time later I found out it's a circuit board problem in the radio. Not happy Jan. In another thread I see Oneup has had the same thing happen and has located the parts to fix it. Fingers crossed it works... as he'll have another one to do!!
