Installing retention screw for pillion seat Streetbob 13
  • Romo
    Romo
    Has anyone installed a retention screw into rear pillion seat position for 13 streetbob. Have checked out all forums and people say its a simple job however the my rear seat position has a plastic guard underneath the fender (with a thread for a screw) preventing me from installing the retention screw bracket? All electrics are also fed through this bracket so i dont fancy removing it.
  • Crustysalmon
    Crustysalmon
    That thread, built into the plastic number plate assembly, is where the seat retention screw goes. The seat screw I have is interchangeable between the single seat position and the pillion seat postion.
    I have removed that plastic tail section on mine, and added an alternative tail tidy, so I had to shift the seat retention assembly (kinda keyhole shape, with the circlip to hold it in place) from the front/single seat position to the back/pillion spot.  If you are keeping that platic tail piece, then you dont need another seat retention screw assembly, or need to move your single seat one.
    Hope that helps.
  • Romo
    Romo
    Thanks heaps! I ended up bending the stock plastic tail section downwards towards the tire and squeezed the retention screw thread (I bought an additional one from harley as I will be switching from solo to 2 up frequently) keyhole between the plastic tail section and the fender which did the trick. The is secured it with the black half washer.
    I know have 2 retention screw threads installed in both the solo and 2 up position for ease of transition.
    Will post photos shortly to assist anyone else with the same issue.
    Thanks again for the reply
