Online: beaglebasher
My 84 softail rebuild and 200 rear conversion.
  • Independant_84
    Independant_84
    Well here goes .
    I was contemplating a 200 rear conversion when a swingarm came along at the right price and got the better of me.
    So far so good modified the horn on the left kicked it out 10mm .
  • Independant_84
    Independant_84
    Made up a 1 inch offset trans plate today.
    Also fitted 3/4 bearings to a late 200 wide wheel.
  • Hudson76
    Hudson76
    Nice work. It'll look the goods when she's done. Look forward to the next lot of pics mate.
  • Independant_84
    Independant_84
    Thanks a lot more work then i thought it would be Had to modify the plate to clear the drain plug on the trans .
    Then notch the down tube on the frame to clear the gearbox.
    Make a wider shock mount on the swingarm out of 25mm round bar and drill and tap it.
    Other things i have yet to do are the 5th trans mount point.
    Re angle the clutch cable fitting to suit the new trans position.
  • Independant_84
    Independant_84
    Slowly getting into it i picked up a 1 " primary spacer from mcas for $20 couldn't believe my luck.
    Mocked up the primary and trans and i had a level that was about the same width as the chain wich has plenty of clearance.
    Just waiting on the axle to arrive so i can sort out the rear sprocket and axle spacers then i can tear it apart again and get into some painting.
  • Hudson76
    Hudson76
    Great pics mate. I am looking forward to getting mine back from the engine builder's and then putting a 200 under it.
  • Squid83
    Squid83
    Looking good so far mate. What tins you going to use?
  • Independant_84
    Independant_84
    Thanks looking at either a fatbob style gaurd like the one in your pic Squid or maybe an extended fatboy style with a the tail lamp in the gaurd. decisions decisions .
  • Squid83
    Squid83
    Sounds good mate, I guess only you know the big picture and what will work. Ill be watching with interest
  • Independant_84
    Independant_84
    Been a bit sidetracked lately trying to find a lathe as i like to do things myself and it is something I had never used before i bought one and got stuck into it.
    I had a 3/4 offset spacer i picked up at a swap meet wich had the 50mm center hole I stuck it in the lathe and made up a disc spacer wich was about 11mm and has a 56mm lip and hole in the back to fit the newer rim.
    Also i had previously taken some meat off the caliper to get it closer to the stopper bracket .And i made some temporary wheel spacers and give them a nice straight cut edge in thelathe.
