Fat ass fitted to Slim
  • Minmoocher
    Minmoocher
    Hey guys, just had a Fat Bob ass end fitted to my 2013 FLS Slim. Had HD do it to keep it all original. I'm taking it back into the shop today but just want some thoughts on the rear suspension. Pre load is at the weakest setting and there is virtually no suspension movement in the arse. Stiff as a board. Went for hoot with the boys yesterday and was lucky to hang on. No pre load it should have plenty of travel but lucky to have 2 mm with me on board. I weigh 61 kgs but a couple of the boys gave it ago, they weigh in at 100 kg plus and same no suspension travel at all. Could swing arm be too tight or something similar or shocks ratshit. It's unrideable for me like it is. After 7.5 k you'd think it would ride a little better. Before the fat end was fitted it did have suspension travel. Eh see wat u reckon, gunna get spun some bullshit from the shop I suppose so thought I'd arm myself with some info or ideas. Cheers.
  • Minmoocher
    Minmoocher
    Cheers mate, I'll try that before I go in to the shop.
    Thank you
  • bobby bob
    bobby bob
    it's a softail isn't it? you wind the shocks in,you wind the shocks out, easy to see if there been wound in maybe to make the rear look good with the fat tyre.
    You fitted a Dyna Fatbob rear to your Softail ??
    Or are you just talking a fatbob wheel ?
    Did they change the swingarm ?
  • Minmoocher
    Minmoocher
    Yep Softail Slim whole new ass end wheel, swing arm, side bars the whole lot. Done by HD.
  • Minmoocher
    Minmoocher
    I didn't like the look with the narrow rear end.
  • pva68
    pva68
    How about a few pics?
  • Gnoo
    Gnoo
    Maybe it was a fat boy rear ya had fitted Mooch.?
  • Daggs
    Daggs
    I'm confused? Do you mean Fat Boy not Fat Bob?
    As one is a dyna and one is a softail
  • Up2nogood
    Up2nogood
    Must mean Fat Boy.
    Would now look like a Fat Boy, I guess? Would like to see what it looks like, and what guard was used.
    pics or didn't happen lol
  • Mungo
    Mungo
    I have a slim also and love the skinny rear end, but would love to see the mod you got done, put up some pic's of your bike.
  • Big Steve
    Big Steve
    Pics are needed as has been already said.
  • Wimbo
    Wimbo
    Got Me why you would buy a Slim and then Fat Ass it anyway.
    It must not have happened lol
