Online: HD17
Big hp evo engines..
  • ds80
    ds80
    What sort of power are people making out of stroker evo engines? I know its a bit of a "how long is a piece of string" question but ive been informed of an evo powered bike im interested in maybe buying. they are claiming engine(big $$ stroker) has been built by a well known overseas top fuel team and producing some serious hp. Im waiting to hear back if they have paper work and specs to back up their claims.
    So in short  how much power is being made out of larger cube evo engines........im aware and have had lager cube twin cams but the evo's i owned earlier in life were near standard so im searching for info.
    i did a evo 97ci mountian motor Axtell cast iron barrels stock stroke  126 hp won bankstown bike show dyno highest outpu back in the mid to late 90's also 113hp out of stock size evo  80ci 1340 c,c, also won Bankstown Bike dyno a few yrs  running , i am building a mountian motor 106 ci evo FXR @tm ,
  • Ando
    Ando
    was at the drags a few weeks ago and a dude rocked up on an FXR with a big cube evo 130+ cuber, claiming 145HP. Went straight out and did a 10.6 pass
    Stay stock displacement and fit a turbo! My Stage 1 80" is around 110Hp with stock heads. plus you can just remove it and fit it to your next bike.
    did a street drag set up back in the early to mid 90's 1340 c.c.  EVO 80 ci used a lot of stock parts 113hp
  • sag57
    sag57
    Not sure of the reliabilty on some of the engines available in the single cam configuration ,S&S 124 weren't to bad but you can stroke a evo to 93"with good reliable honest horsepower with out the wank factor . lf you can get hold of some of the more notable engine builders of the day l am sure they will build you an engine which will make you smile.
