Upper shock mount torque setting?
  • Greeneggs
    Greeneggs
    Anybody know the correct torque setting for the upper (& lower while I'm here) shock mounts on a 2015 FXDB Street Bob?  Have to drop the swing arm to do indicator relocation etc.
  • Crustysalmon
    Crustysalmon
    Just a quick copy and paste from the 2013 Manual. You really need to spend the $70 or $15 digital dowload to get one of these. Lost count of the times I've referred to it, even with the simple things I've done like bar changes etc….
    INSTALLATION
    FASTENER TORQUE VALUE
    Shock mounting stud nut, inner, 75-85 ft-lbs 101.7-115.2
    Nm
    Shock mounting fastener, 30-40 ft-lbs 40.7-54.2 Nm
    lower
    upper
    1. See Figure 2-100. If removed, install stud (6), hardened
    washer (7) and nut (8). Tighten to 75-85 ft-lbs (101.7-115.2
    Nm).
    2. Fasten each shock to the frame and rear fork using the
    original hardware.
    3. Attach lower shock mount to rear fork.
    a. Apply two to three drops of LOCTITE 243 MEDIUM
    STRENGTH THREADLOCKER AND SEALANT (blue)
    to threads of bottom bolt (1).
    b. Install bolt and hand tighten.
    4. Apply two to three drops of LOCTITE 243 MEDIUM
    STRENGTH THREADLOCKER AND SEALANT (blue) to
    threads of upper mounting nut (2).
    a. Install cover (3), shock (5), and washer (4).
    b. Hand tighten upper mounting nut (2).
    5. Tighten upper and lower shock mount screws as follows:
    a. Lower mount: 30-40 ft-lbs (40.7-54.2 Nm)
    b. Upper mount: 30-40 ft-lbs (40.7-54.2 Nm)
    6. Adjust shocks if needed.
  • Crustysalmon
    Crustysalmon
    ...But it you are doing the GBG tail kit, you probably don't have to undo/ take the suspension off. I didn't. I guess it depends on how big your hands are.
    I was able to tuck the wires back behind the plastic retainers etc with out doing that.I jacked it up a tiny bit bwith a floor jack, just until the wheel was off the ground and that was enough clearance for me.
    I knwo the first line fo the GBG kit says to disconnect the suspension but....
  • Greeneggs
    Greeneggs
    Thanks guys, appreciated. Got 10.5" Burly Brand slammer shocks on.. Nothing gettin in under that fender unless it's fluid :)
  • Crustysalmon
    Crustysalmon
    Ah. Of course....
  • robrooter
    robrooter
    hey crustysalmon, where can you download one of these manuals from. i have a 2014 fat bob and i need to know the torque settings for the handle bar mount.
    thanks
  • Crustysalmon
    Crustysalmon
    Somone has a dropbox link in this thread that seems active still...
    http://www.hdforums.com.au/Default.aspx?tabid=71&forumid=4&postid=586041&view=topic
    or try:
    http://www.motorcycle-manual-download.com/index.php?main_page=product_free_shipping_info&cPath=3&products_id=169
