Online: John.R
Engine mount Stabilizer Options
  • Ando
    Ando
    Right Dyna Crowd apart from TruTrack and Sputhe want if any other options are there?
    Also what do you blokes prefer? I'm leaning towards the trutrack because of ease of payment and shipping as they both look pretty similar but interested in your thoughts?
  • chriso
    chriso
    I went with the sputhe Ando mostly because I think it looks just that bit more compact.
    Also read that Eric Buell helped design it and it is a tad better technology then the try- trac
    I actually bought one a mth ago for a mate. Went to bank deposited money , emailed Allan
    deposit number and had it in 2 weeks.
    I have heard of people having trouble hearing back from him but he is just a small business,
    believe it or not and does nearly all the running of it himself. I guess that's why at times
    communication isn't the best,although that's no excuse.
    My mate actually spoke with him and recons he a real nice guy though.
    Both will do the job for you though mate
  • BDA103
    BDA103
    Sputhe is a more compact and well designed, looks like its meant to be part of the bike and doesn't appear out of place. Definitely the way to go IMO. When I was buying mine I had a fair bit of correspondence from Alan and he is a good guy, very helpful. The rear mount is a trick to fit on your own when on the floor but is no issues when using a lift. Done two now and LJ's was a doodle compared to the first - difference being the bike lift and an extra pair of hands. The Sputhe just looks better made to me, out of machined components compared to the TrueTrac I saw earlier on. The only negative is the method of payment is a stuff around as Alan doesn't do credit card or PayPal. Give me a call if you want Ando
  • BDA103
    BDA103
    PS you can run the Sputhe and a HD oil cooler together with a very minor mod to the oil cooler mount bracket. Not sure if you can do same with the TrueTrac
  • Ando
    Ando
    Hilly I am leaning towards the True Track that's for sure because the ease in getting one, I can't be fucked having to do bank transfers and waiting on emails ( Like my pipe)
  • BAKES
    BAKES
    G'day Ando, I went true trac, makes a big difference.
    As the rest of the guys say, the rear one is a mongrel to install
  • carbon fibre
    carbon fibre
    do it sooner rather than later, 120 will destroy stock engine mounts in no time.
    maybe fix me up first though.
  • Daggs
    Daggs
    I fitted the sputhe but haven't really noticed much improvement but that might be because I have spent a fair amount of time aligning and centering everything on my bike over the years.
  • Ando
    Ando
    True Track on its way
