Online: baldy1450
Homemade polish
  • philthy
    philthy
    "Brass,Copper,Chrome and Pewter.                   Prepare a paste using vinegar mixed with one tablespoon of flour and two teaspoons of salt. Add enough vinegar to make a thick paste.Apply to the metal with a clean cloth."     Copied word for word from a book "Vinegar. Natures secret weapon" by Maxwell Stein. Haven't been on here much guys, all good tho. Hope you all had a bonza crissy and will have an even better new year. ??
    Prolly works, but since vinegar is an acid I think I'd be washing that shit off when finished.
  • FLIPDOG
    FLIPDOG
    salt and vinegar, could one just rub a packet of chips into prescribed area?
    salt and vinegar are very corrosive materials, doubt if would use it. Why not just buy a quality soft polish such as "PURPLE" ya tightarse, homemade hippy concoctions are idealistic environmental bullshit.
    I just bought some purple polish now that you mention it. $30 on special at autobarn. I'f I'd heard about the vinegar salt thingy before I bought it I might have given it a try.
  • 92Fatboy
    92Fatboy
    I used to polish my black car with vinegar and it worked really well for removing minor marks and giving a high gloss finish. Was the only thing i could find that worked.
  • keith
    keith
    Vinegar alone does a great job when cleaning windows also. Thanks for the tip Philthy
  • FLIPDOG
    FLIPDOG
    Oh, by the way, thanks for the thoughtful tip man. After all this is what the forum is about...cheers
    P.S. How do you do that highlight bizzo Sparra?? Is it click and drag?? Not real savvy at this shit- not so long ago worked out how to start new paragraph
    (by accident)
