Online: John.R
Open face helmet
  • catack
    catack
    Hi guys, I'm looking for a open fave helmet, one that I don't look like Marvin the Martian.. I like the cannonball helmet, but it's not Australian standards... Can someone help with a good helmet please..
    Nex or xrh but you'll need to try them on as not all helmets fit well on all heads
  • Geoff3DMN
    Geoff3DMN
    What have you got against Marvin?
  • Nomada
    Nomada
    All heads are just as different as helmets.
    what fits for one may not give you the look your after.
    Best bet is to go into a shop and try some on.
  • DAVUTCH
    DAVUTCH
    Wow this had been done lots go try 50 on you'll see how ugly you are in all of-them mate
    Everyone looks like a numb nut in an open face
  • Mr.Mow
    Mr.Mow
    For anyone who cares, peter Stevens online store has the bell 500 open faces for $69 at the mo..
  • DR
    DR
    +1 for the Nex, it was the lowest profile I could get and it's comfortable. good helmet for the price.
    I'd wait to see what the new helmet laws are before buying a new one, (that's unless you have dropped it of course).
    You might be pleasantly surprised in the new year.
    There's a cheap xrh helmet in large and matt black colour, supposedly unused, on gumtree for $50 right now
  • Sparra
    Sparra
    Any one who has grabbed one from Peter Stephens what size do you normally wear,what size did you order and are they the same size??? I usually wear an xxl so wondering if one of there's in an xxl will be the same....
    Sparra. I had to go a size up with the bell. Normally a med to large depending on the make. With the bell the large fits but is tight, so this time I went XL just to have a tad more room..
  • hosh
    hosh
    If you have the coin these are a very good helmet. http://www.shoei-helmets.com/Helmet.aspx?J-Cruise&h=23&t=1
    I took two of these to the states (one for the wife) and did 12k klms through all sorts of weather. Torrential rain, above 40 degree heat right down to minus temps in Canada. Not a drop inside. The retractable sun shield negates the use of sun glasses (no more pain above the ears).
    One drawback was the speaker recesses weren't quite deep enough for the HD OEM intercom sets. 20 mins and a little care with a small knife sorted that out.
  • Mr.Mow
    Mr.Mow
    Bell 500 arrived from the peter Stevens sale and the small is fine for me, as I mentioned I'm a small in shoei, agv and arai.. But a medium in a bell bullit..
  • HogBag
    HogBag
    I've been using the bell shorty the last year and happy but it gets a bit noisy and the rocks bugs and rain is starting to get to me these days. I must be getting old as the shark evoline flip face is starting to look good to me.
  • graeme
    graeme
    I use a kbc open face fits perfect
  • dkNigs
    dkNigs
    HUGE difference in sizing between last years Bell 500 and this years. Same size that's too big in the RSD for example is too friggen small in the new ones. Bottom seems to curve in a lot more now.
