Shotgun Shocks Breakout
  • goldiedg
    goldiedg
    Hey Guys,
    Just ordered a set of Shotgun Shocks and waiting for them to arrive. I am in the Eastern suburbs of Melbourne.
    Doed anyone know a good place to fit them around the area or happy to travel to somewhere in Melbourne?
    Cheers & thanks for the assistance.
    Dave
  • ucmitch
    ucmitch
    In your Garage with a six pack ;)
  • goldiedg
    goldiedg
    Ha ha ha...it would take me a slab, and it still wouldnt be right!!
  • Big Steve
    Big Steve
    Doc Hogs in bayswater
  • xlr8it
    xlr8it
    took me about 2 hours to fit them , not hard at all
  • rodrocket
    rodrocket
    Let me know how you go fitting them as I have a set hiding in the cupboard that I bought for my softail & never fitted, planning to put them on my Breakout along with a few other mods :)
  • Volvi
    Volvi
    Just take one tip from me, if your not going to fit yourself make sure the shop that does has done one before. Otherwise you might be paying extra time just for theyre learning curve. I had bad experience with sloppy shop doing it for me. end up costing me 5 frakking hundred just for fitting, allbeit few times on and off due to other probs. if not experienced get firm quote first with no more to pay. am SE myself.
  • goldiedg
    goldiedg
    Thanks for the replies...yeah i hope i come across a compnay that has fitted them before as it would be good if they know what they are doing!!
    Doc Hogs is just around the corner so i will try them..
  • goldiedg
    goldiedg
    Ok, so i just got my exhaust, cam pipes & tune done at Eastern Big Twin, Brian the owner is a magician. Cant beleive the difference in power & performance.
    He is also going to fit the Shotgun shocks for me...Highly reccommend this place!!
  • Squid83
    Squid83
    Shotguns are a piece of piss to fit. Save yourself the money and do it yourself I reckon
  • xlr8it
    xlr8it
    Did mine tonight , took 2 hours, easy as long as you have basic skills and tools.
