Going to do a 200 rear conversion on my 2006 Custom. It might take a while because all the parts have to come by mail. As things show up I will post updates.
Step 1: Get the Bike.
Step 2: decide on what wheel type and size
Step 3: order said wheel.
I have gone with a 6X18" with 60 spokes [I like the look better than a mag]
A 200/50 x 18 will give me the same diamiter as the stock Sportster tire so no need to calabrate speedo
Step 4: unpack my new toy
Picked up another swing arm today, things are starting to come together.
Modified the swing arm, fitted and spaced the disk and pulley and knocked up some temporary spacers. Still have to fit the axle adjusters and brake caliper before I can make the final axle spacers. Happy with it so far.
looking good , will be good to see when finished
Another part arrived today, getting closer. Step by step, little by little.
Been busy the last couple of days, got the axle spacer "cut yourself" type which inspired me to make my own axle shaft/drive belt adjusters.
Using the disk as a base line to work from I worked out how long the spacers for each side should be the cut them to length.
This is what I have so far. Also ordered the rear tyre today.
Another piece closer, this arrived today from the USA. Still waiting for wheel and bearing shims to get the setup perfect, a 1 7/8" socket and the new tyre. They are all in the mail. I am not 100% on the rear guard yet. I would like a big FatBoy rear guard but haven't been able to find the one I want yet
A couple of bits turned up today, the tyre [at last] and a brand new 1 7/8" socket. Getting closer.
Oh the reason I don't have the tyre fitted yet is because I was working on the front end. Installed a Valcanworks + 3 deg rake kit and a set of +2" tubes.
Old tyre + New tyre
Good stuff. Looking forward to seeing it finished.
Well done Jinda , keep the updates comin .
