length of back shocks on shovel frame
  • evoshovel
    evoshovel
    I have a shovel frame with the round swing arm and 12 inch shocks. The swing arm goes up hill from the frame pivot, I think it should slope down hill so when a bit of weight goes on it or over a big bump it is a bit more level with the ground. Has anyone got a simerlar set up and if they do what length shocks do they use?
    i have a pair of  13" Dyna stock shocks you can have for 50 buckaroonies, the early model had longer shocks
  • evoshovel
    evoshovel
    Sounds good my number is 0428073074 give me a ring to sort out money and freight and stuff like that.
    the centre to centre is 12 3/4" or 323m.m. the mount post are in line there not off-set
