Online: evo94
Quiet Baffles - V&H Short Shots
  • Squidsy
    Squidsy
    Gents,
    I'm running V&H short shots on my 48 with quiet baffles and have decided they are a little bit too quiet.
    Maybe a dumb question but would there be any issue running one quiet baffle and one stock baffle? Aiming for a best of both worlds kinda thing so it's louder than right now but not as full-on as straight through on both pipes?
    Tom
  • ANDYK
    ANDYK
    Try running the quiet baffles without the packing in there thats what i have done
    I was told you should try to keep the pressure through both pipes equal...but I have no idea.
    For my personal quest I tried quiet baffles (yawn) and the normal baffles (raspy ear breakers), then quiet baffles with the end caps removed, then quiet baffles wrapped, then half wrapped.
    In the end I think I went normal baffles with a lolly-popped pipe so I could just adjust the sound.
