Online: evo94
Stock suspension on 48
  • Sticky
    Sticky
    Hi guys.
    Could somebody do me a big favor and measure the distance between the bolts on your stock 48 rear suspension.
    Mine is 180mm centre to centre.
  • brash
    brash
    that doesn't sound right, that's 7 inches, would literally have the guard sitting on the tyre.
    off the top of my head Aus delivered 48's have 12 inch eye to eye shocks
    I'm confused lol
  • Sticky
    Sticky
    Sorry, that was a typo 280mm is what the stock shocks are from the centre of the bolts, fitted - which is 11".
    I just bought progressive's at 11" as I was told it would lower the bike 2", I should have checked.
    The ride hide is the same, just brutally uncomfortable.
    I wonder if itd be worth getting a lowering link now that I have stuff springs..... It didn't work well with stock springs.
  • dkNigs
    dkNigs
    The 48 is lower than other sportsters standard isn't it? Might be the confusion.
  • Sticky
    Sticky
    Yeah...... An expensive confusion.
