Turbocharging sportster
  • Sticky
    Sticky
    Hey guys
    I've decided to turbo my 48 and was wondering if anyone here has done it - especially in Qld
    I am thinking of using procycle dyno in slacks creek for a custom set up as I don't like the look of any of the kits that are on offer
    Any help or input would be rad
  • HogBag
    HogBag
    Fred wont let you down.
  • Sticky
    Sticky
    I took my r6 there for a dyno and was really happy with their service.
    I'll head in early jan and have a chat.
    They seem to have a good background on Dyno tests & tune, BUT that's bugger all of a Turbo install.
    You really need to be looking for someone that has experience in that field - and if Pro Dyno have then all is good!!!
    Hope you have deep pockets as its not a cheap path to go down if your outsourcing it to a shop to do, but NOTHING is better than a turbo Harley! Check out Procharger as they may make an item for your machine.
  • brash
    brash
    have a read on the XLforums, lot of info floating about about turbo sporties on there.
    trask do a kit that bolts right on.
  • Sticky
    Sticky
    The trask kit looks like arse though.
    I'm happy to pay a premium and have it custom done to have it look much better.
    Aerocharger make a very tidy unit! (No oil lines and no wastegate)
    I have one mounted on the left side of the bike so the plumbing is very tidy.
  • Sticky
    Sticky
    I thought aerocharger stopped making stuff?
    Do you have any pics?
  • TD302
    TD302
    Don't go to the old shop Freds moving shop over the break. Now will be on Herbert St off Moss St.
    PM "DynoHarley" as well. He alslo has a turbo bike that puts out more power than you can shake a leg at.
  • nhb006
    nhb006
    Did mine my self. - Tuned by Neville Lush.
    Made 146hp @7psi
    The turbo project cost me $3 grand in total...
    There a thread here somewhere on it.
    sorry to hear that , what model drag bike do you have cheers Bob   , i am also after a few inch extend s/arm for two different model's
