Online: John.R
best solo
  • Steve L
    Steve L
    as above what is the best solo and why, I really like the new 2015 CVO Street Glide seat but at $550 its hard to spend that much just on a solo, its another $440 for the pillion, or I would need to exchange my solo for the badlander any time the missus wants to come along. I can get a Le Pera Villian solo for a reasonable price but am doubting it would be comfortable for anything over an hour or two. I also really like the look of the Saddleman Dominator seat but cant find any specs on it. I am only a short arse at 5'7 and am looking for the most comfortable lowest solo I can find preferably with a pillion available as well.
    pic below is the Dominator
  • Neale
    Neale
    Have a look at mustang, I put one of their solos on my FLHT and it's as good as the original that came with my bike when I bought it new. Which is an ultra seat. 65,000 kms later I'm not complaining.
    Keen to hear the answers for this one, have jammed a std ultra seat on my street glide and done 42k on it with no issues but look at a single all the time.
  • Steve L
    Steve L
    thanks mate I have looked at them and many many others, the problem is not being able to sit on any to see if I like them.
  • The Black Pearl
    The Black Pearl
    Put Santee brand , dont know style name on my 09 SG a few yrs ago .$320 from St Pauls HD in US . Very comfortable and not too high , suits lines of bike and can ride all day.
  • Chaser
    Chaser
    Don't you have to drill the rear guard so as to fix the seat? That would put me off.
  • Steve L
    Steve L
    couldn't find anything on a Santee seat and what seat are you talking about Chaser.
  • Chaser
    Chaser
    On the Ultra, basically the same as the SG, there is a main screw that holds the rear of the seat to the guard. The seat is a 2-up seat and there is no facility to put a smaller seat on unless you drill a new hole in the rear guard. I assume there is a tab at the rear of the seat for a screw. Is this the case?
  • Steve L
    Steve L
    under my seat there are 2 bolts which can be used for fitting a solo or attaching rider backrest. Mustang seats bolt up to them and some over brands have adapter plates which mount to them.
