Hi guys, I'm looking at living my Harley dream and getting on on ASAP. I've never had one and am not the most knowledgable on the different types out there. But, I'm tossing up between a night train, breakout or a nice heritage soft tail.... What's the main difference between them all ? Night trains seem pricey but look great, breakouts are newer and around the same price as say a nice night train. Also, I'm a short arse (5'6" any help or pointers in a good direction would be hugely appreciated!!! Deadset keen to get into the Harley community! Thanks guys.
first man welcome to the forum pages,great to hear your deadset fuckin keen .Ok, if you've got a leather cap and arse-less chaps get yourself a heritage ,if not, then definitely consider the Night Train, softail standard or softail custom which are all the same bike apart from colours and chrome differences on casings. You will probably very quickly feel the urge to step up from a sporty in my opinion. (I maybe wrong of coarse) The Breakout are indeed a nice machine but take some riding having got the 240 rear tyre and more front end rake on them (they tend to want to go straight). they also don't have a lot of ground clearance on them either therefore only having a lean angle of 24 degrees (youll scrape on round abouts)compared to that of 35degrees on a night train, softail standard or custom. Like 92fatboy said sportys are exciting to ride. I am also a 5'6" short-arse cunt and have no worries what so ever with my fxst (softail standard-danny gray solo seat-lower seat profile) Do some heavy research man the info is all out there and get some comparison notes going, ride a few and get the bike YOU want straight up(don't be a tight arse, youll be sorry later) and you wont have to buy another down the track cause your not satisfied. Whatever bike you decide on you will, like all of us, buy custom bits and blingy bits just to make it your own. Whatever it turns out to be make sure ya give us all a look ay.....GOODLUCK......Best regards to ya Fella...... FLIPDOG
you got it mate, like I said nightster, standard and custom are physicaly exactly the same bike, HD pricing goes like this entry level are sportsters next are the dyna series (all dynas have exposed rear shock /springs) then theres the softail models top of the line are touring models (roadking etc) Check out the standards that have solo seats just to get a better idea of what they truly look like as the stock two up seats take away the look of them I reckon. When you get one youll probably change the bars and seat eventually just to customize the way YOU fit the bike. Also look and ride better with arse end lowered an inch and a half mine fits me perfect with these things done. By the way just go a stock standard engine mate 1584cc 6 speed should be plenty for you straight up and will give you room to move a little later on to do mods that suit your riding style..Regards FLIPDOG
You didn't mention if you had a full license, if you don't you won't be able to ride a Harley until they bring in the LAMS bikes early next year. Unless your live in the ACT they can ride any sized bike.
If you do have full motorcycle license just go and test ride, nobody can tell you what bike is right for you they can only give you options.
Hope you find what your looking for.
Ha Ha... had the same experience... bought the Harley without riding it first because it wasn't registered with the previous owner... so I registered it and picked it up on Friday the 13th last year... the misses said I shouldn't pick it up on Friday 13th but I couldn't wait... anyway the bike vibrated like hell all the way home (I also have a Suzuki GSX650F) so I was used to a very smooth ride. For the first month, I thought my eyeballs would be affected because of the vibration but as time went on I adjusted and can ride with great enjoyment now, In fact now I love the feeling of the bike with it's incredible take off power... the incredible sound ... it's truly a great buy for a 14 year old bike and it looks like it just came out of the showroom and mechanically as well... I love my 2000 Custom Sportster XL1200... It's black and covered in chrome... and that chrome spoked front wheel... geez she looks great. If I want a smooth silky ride I get on the Suzuki but if I want to feel alive and stir up the neighbourhood I fire up my Sportster... she is such a beautiful machine.
Yeah I know you can buy the newer rubber mounted engine Sportster, but there's something about a motorcycle with the engine attached directly to the frame... especially a V twin... it has a raw power which you can really feel right through your body... it's not for everybody but once your hooked you get an amazing riding experience everytime you ride it.
