10" risers
  • Lodgie
    Lodgie
    I have a 2014 fat bob with abs and dual disks. I want to put on a set of biltwell 10" risers with my stock bars. Anyone have any experience with that? I've heard that the street bob cables will do the job? The stock risers are 5.5" and apparently there is some spare electrical cable so they don't need to be extended? Anyone done something similar even a 10inch t-bar cables should be about the same for dynas? Thanks
  • Lodgie
    Lodgie
    Whoops wrong forum, supposed to be in the dyna section. My bad
  • Soapbox2627
    Soapbox2627
    we understand lodgie, has a Dyna, but wished it was a Softail.
  • Lodgie
    Lodgie
    I'm just happy it's a harley after being stuck on the p plate system =P
