LED indicator question
  • robots
    robots
    Hi,
    Put custom dynamics LED inserts in rear indicators on FXDWG and all fine, hard wired up
    Thanks
    Robots
    With the majority of LED indicators on the market, yes, you would still need to add some form of extra load to replicate the front filament lamp.
    Having said that, I don't know if the new Vrod/Livewire LED's have a built in load or not.
    You need resistor of around 6 ohm's  for every lamp you remove.  Or a plug in electronic unit is safer with less heat.
    CAN bus/later model bikes may be different.
    A quick test, just unplug one indicator and try it.
  • rider
    rider
    Ya could give it a try Hilly, but I think ya would prolly end up with fast flashing dictators if ya didn't compensate the flasher circuit with
    load equalizers.
    Few other options ta gin around with would be to find a flasher unit that was made for that set-up. (lower resistance rating), or,
    Fit yar own resisters inline with the front flashers.  (as speedy says, around 6 ohm per light) jaycar or such.
  • Urban Guerilla
    Urban Guerilla
    +1 on Badlands load equalizer, Hilly,
    I'm pretty sure that the badlands is the only, or one of a few that are "Parade rated", as in they've got the overheating situation sorted out. You can run your hazards all day (as you do in a parade).
    I have LED's on the rear, and bulbs up front, and have had a badlands fitted for 2 years. Never a problem.
    You made a good choice in contacting them I reckon.
  • rider
    rider
    Aye Hilly, geeze, all this talk of purdy LED flashing lights and parades and stuff,,, you ain't thinkin of doin the old girl up with all them Christmas sparklys are ya ?
  • terroristone
    terroristone
    CAN bus bikes dont need a load equalizer, the BCM regulates it.
    T1
