Online: evo94
What front end is this ?????
  • Stealth softy
    Stealth softy
  • Squid83
    Squid83
    Its the stock FXST front end
  • FLIPDOG
    FLIPDOG
    I agree stock FX with custom light, custom bars.
    Why do you ask?
    I assume the bikes not running in pic- If it isn't running, I would advise you get into the habit of switching bike off with ignition rather than the kill switch to save you returning to a flat battery. (using kill switch to shut down and forget to switch off ignition is very easily done if distracted).
    Also kill switches have been known to fuck out at times in off position with constant use, therefore not allowing you to restart. And you can bet ya balls if it happens it wont be in the garage at home it'll be when your having lunch somewhere mid-ride.
    By the way, nice bike man (I have to say that cause its pretty much exactly the same setup as mine)
    Cheers stealthy
