NEW SUNDOWNER SEAT ON FATBOB
  • shingles
    shingles
    was getting sore after 100k,s even before was movin around on seat ya know tryin 2 get comfy,didnt seem like was as comphy mite av lost 2 much padding on myself rear end sure seems 2 feel it more, but roads aren;t the smoothest as could be an i av lost beef so looked at options buy from os or here or get refoamed with better density foam that made smoother.  Got qoute 300 plus geezez went 2 HD shop nah rang sys harley first see wat costs new smoother seat as there is new range in parts cat the 1 i wanted looked same as standard fatbob ,but has bladder an u pump this with hand as 2 what feels best as goin along and has seude or somthin not unsitely an u can adjust as ridin along ,then cost dropped me like A  wat da geez 757 buks but we hav others sundowner 450 ,so went 2 my shop and asked do u hav 1 ,no we,ll get 1 in and if u like look its yours didnt wana spend that much ,got another brand new reduced reach seat for bike as well but didnt fit way i wanted in riding anyway ,bit bullet bought the sundowner seat and hav 2 seats 2 sell both fit fatbob and lots of dyna range as well ,was new seat better rode 100+ k,s and yes seat is more softer but sits u forward in perch coupla inches and little bit higher ide say but is more forgiving coz i rode on some shit roads and smooth overall yes better but feel like i wana get ass back further thats only real drawback ,but over time seat will compress has more area 4 passenger and higher foam main seat wider a bit ,but hasn.t hindered my feet on ground at standstill not tippy toey ,an can always lower rear shock a notch ,ah better still new shocks  FROM YSS OZ need 2 sell other seats and all other items need 500 buks 4 that always sumthin just never ends ,with everything bills 4 this bills 4 that an i cant work anymore ,cant even get job delivering pamphlets SEAT PRICE 410 better than sydney price i leaned on them a little and 50 buk off well av spent quite a bit with dealer that helps 8-9k over few yrs SHINGLES
  • 92Fatboy
    92Fatboy
    try fitting a sheep skin cover to the stock seat should do the trick. Also ride smoother roads or slow down on the shit ones so not as bumpy .
  • 06 Softail
    06 Softail
    I'm getting rid of my sundowner seat as soon as I have the cash for tall boy seat for my softy.  Being 6'2" and having a couple dodgy discs in the lower back, riding the 96 kms each way to work is quite uncomfortable. I can't even stretch my legs unless I hang my heels over the pegs, where as having recently testing out the tall boy seat for a week or so, even doing a return 1000 km road trip from Adelaide to Edenhope Vic, was so much more comfortable and was able to straight leg it for a change with feet firmly planted on the pegs.
