Online: John.R, Merv
Nissin brake upfront on Fatboy
  • pdsbuy
    pdsbuy
    Hi all, i'm new to the forum and have a question that some of you could possibly help with.
    i've got 09 Fatty, as you would know Softails have rather poor brakes and have been gathering options on brake upgrades.
    Anyone done an upgarde using a Nissin calliper from a Harley XR1200 up-front, supposedly the braking is improved quite radically when coupled with a floating disc..?
    This calliper is a straight bolt on and works great, can someone comment..
  • Harry28
    Harry28
    Having both an XR1200 and a fatBob with 16" wheels. I measured them up roughly and concluded that the Caliper would run too close to rim. If it does fit it would be tight. The Nissin caliper is pretty big compared to stock.
  • pdsbuy
    pdsbuy
    thanks for the info mate, im going to check with the Harley dealer and keep digging, my concern is that if this is a good mod i would think there would be people out there who would have already done this
  • deluxe 1
    deluxe 1
    i have been told that the brakes are already nissin
  • chriso
    chriso
    mate had one on his heritage and swore by it
  • Cartoon Head
    Cartoon Head
    I've just put floating disc's and a PM 6 piston caliper along with the PM 4 piston on the rear. This improved the braking so much so that it felt like the front suspension was diving.
    Having Progressive's on the rear already I matched that at the front using the Mono Cartridge Progressive's, massive improvement over stock. Still not anywhere near a Jap bikes handling and braking but for a Softail it now handles and stops well.
    The other way is to go with the Brembo conversion.
  • chriso
    chriso
    i just did brembo conversion on softy, bolt straight on with no mods
    It can be a bit of a crap shoot when it comes to caliper selection. I have an older FXR with spoke wheel and there are bugger all calipers that will actualy fit without hitting the spokes.
    ther thing to watch out for is to not buy calipers that are used on anti-lock brake bikes. They have an odd setup with their pistons etc.
    That's the same caliper I have on my evo softail ,got mine out of the states 18mths back for won of
    My projects There the same as victory I believe but I did change the the pads to lyndells
    This should work on yours tussuck
     forgot the name of the guy that sells them on eBay USA but has sold shit loads of
    Them they do hit sportster alloy spoke wheels apprently
  • steelo
    steelo
    Setup looks very smart. Thanks for posting pics. I went to site, quite informative.
  • chriso
    chriso
    make sure you state what your putting it on mate cause they all diffrent
    Don't forget about the factory Brembo conversion with the 300mm discs. On my Dyna I'm using twin discs and Brembo MC, but it can be done with a single.
    Generally just two finger braking, this is a serious performance upgrade.
  • Dutchy Hoogen
    Dutchy Hoogen
    So is there a brake upgrade for the fatbob with twin disks and abs. The standard brakes pull it up ok but start fading pretty quickly. Nearly pulling the lever all the way to grips yesterday and brakes did not start working until lever was half way in.
  • chriso
    chriso
    Well that's strange I nevered bothered getting the brembos for the bob cause very happy with them.
    I do suggest changing to lyndal gold pads though, made a big diffrence
  • chriso
    chriso
    yep good enough for me too.
    The softy was a diffrent story though .something had to be done, fckn stock brakes were none existent
  • Independant_84
    Independant_84
    I went from the old single piston caliper to a late model non brembo type 4 piston now it nose dives huge improvement.
  • triumph68
    triumph68
    ive  put a drilled out gsxr slopeing type f master cylinder $25 bucks from the wreakers and duel 4 pot brembos on my fxr it pulls up in a hurry harly brakes are shit
