Online: John.R, Hilly
Clutch Issue
  • BLKACE
    BLKACE
    Howdy.. new to the forum.  Ive jsut brought a 1990 custom softail.  Its fitted with 5 speed trans, 3 inch BDL belt drive and S&S 124 V motor.  The issue I have is the clutch.  Redicolously hard to squeeze, The bike has just been serviced and nothing was said about it so a part of me thinks it might be right... Can anyone recommend a good bike shop, preferably eastern suburbs of Melbourne that does quality works, stands behind and more importantly, gets its done when they say they will. Im keen to have the clutch checked and replace the cracked exhaust.
  • Harry28
    Harry28
    Eastern Big Twin over in Bayswater. They are also a forum sponsor and do good work. Give Brian a call.
  • BLKACE
    BLKACE
    Cheers for the response
  • Hallze
    Hallze
    Yep, go over and see Brian at EBT. Top bloke and does a great job.
