Online: John.R, Hilly
FAT BOB SEAT FOR DYNA
  • DAVUTCH
    DAVUTCH
    CAN ANY ONE TELL ME DOSE THE 2011 FATBOB STANDARD SEAT FIT A 2008 DYNA STREET BOB I KNOW THEY FIT THE LATER BOBS
    CHEERS DAVE
  • Big Steve
    Big Steve
    The first mustang seat I had bolted straight on to a 2012 fatbob so yes (2010 & 2008 streetbob a being the same)
  • pva68
    pva68
    All Dyna models from 2006 onward have the same frame and seatpan... So yes.
    I took the mustang solo seat from my 2008 FXDC when I traded it on a 2014 FXDF and the seat bolts straight on... like it was made for it. :)
  • Krackers60
    Krackers60
    The best way would be to check it out in a parts catalog, hardcopy or on line.
    The description always tells you what bike the part fits, so you should be able to work it out that way.
  • DAVUTCH
    DAVUTCH
    thanks guys appreciate the help
  • Daggs
    Daggs
    Yes mate they are all interchangeable
