Licence plate lighting
  • theonly_bk
    theonly_bk
    Planning on relocating my nightster's side-mounted licence plate onto the sissy bar. Are there any issues with this? Does it need to be illuminated in NSW?
  • Iron
    Iron
    I think you will find that all licence plates need to be illuminated in every state so the cops can read your rego plate at night time.
  • Darbcore
    Darbcore
    Hi, I just took off my standard license plate light and cut the wires, I want to re wire them with the little LED lights,
    Any issues I need to look out for??
  • Darbcore
    Darbcore
  • Urban Guerilla
    Urban Guerilla
    I don't think that there's be too many issue with doing this as they don't need to flash. That seems to be when you have to start looking at how much current they draw, and load equalizers etc. But just a straight swap from globes to LEDs, it's easy swap over.
  • brash
    brash
    just don't burn your garage down when you solder them :)
