how about a recall (re bearings)
  • Sim
    Sim
    M
    Hi all
    My 2011 Fat Boy was just serviced at 22K km all good.
    900 km later rear bearing goes.
    It went while parking, so I limped home in first gear.
    I know HD do not use these bearings any more, but why should we pay for their mistake.
    If you agree and have receipts for low milage bearing replacement please reply.
    Sim
    You would still be covered under Australia Consumer Affair laws, investigate further, why should you pay good money for a machine that breaks down after 24 - 36 months, from a faulty part....
  • Sim
    Sim
    rear wheel bearing,
    Do you use a gerni to wash your bike?
  • the_mongrel
    the_mongrel
    Hmm... I have a 2010 - might have to check it out.
  • oneball
    oneball
    Hi all...Yep,My rear wheel bearing went on my 2011 fatboy low at 20000klm...
  • Jimmy The Human
    Jimmy The Human
    it's probably a bit extravegant but I replace both wheel bearing every second set of tyres!!
    cheers Jimmy
  • mickle
    mickle
    I suspect some of these failures are caused by incorrect torque of the rear axle after tyre changes.
  • Harry28
    Harry28
    They're just shit quality mexican bearings. Get some quality ones in it an move on.
  • markwoumla
    markwoumla
    I can understand if a stock Harley bearing fails in a low km bike its not a good look !!! Especially with all the reports of this happening ..
    For fuck sake ,,, we only have 2 wheels !!!! Could a large % of failed bearings be put down to DIY install ???,,, maybe !!! ,,
    I've done approx 400,000 km on 5 Harleys , ( replaced bearings, (stock Harley) , after third or forth tyre change ) , and never had a bearing failure ,, am I lucky ?? ,, maybe !!
    I can only speak on touring models,, 2009 seemed to be a bad year for the stock standard bearing, (non abs), 9276 , in about 2011, they replaced the 9276 with a 9276A . The abs bearing , 9252 , has not changed , and doesn't seem to be a problem..
    I realize you can replace the standard bearing with a aftermarket bearing .. But from what I understand , (if you have abs), the abs bearing , 9252 , has to come from Harley. If anyone knows of a aftermarket abs bearing to replace the Harley abs bearing 9252, please post up..
  • Sim
    Sim
    no high pressure wash, just the garden hose.
    I've heard of a few going at 30K-40K.... mostly softails. Latest was a mate in Melbourne with a Fat Boy Lo. If anyone uses high pressure wash then it's the stealers. My 2007 FXDB had the rear wheel bearings changes after 80K..
  • oneup
    oneup
    i have pulled rear bearings out of a few newer HD's 2007, 2008, 2009,, so it may go a lot further... and have found horrid cheap nasty collapsed bearings.. these are easily recognised as crap because A they are fucked.. and B they have no writing or any form of identification on them.. god quality replacement bearings are cheap. HD should be responsible for its crap but they know we wont stop buying so why should they give a fuck..
  • oneup
    oneup
