CAMS chain drive versus gear
  • gidgi
    gidgi
    Hey there I would like some veiws on differences /drawbacks on chain driven cams in stock 103 V gear drive. I realize this could open up a can of worms & possibly be  an intervidule thing cheers in advance
  • Ando
    Ando
    for me I wouldn't bother as I have opened up a few 103's and never seen one under .003" crank run out
    mor choices of cams with chain and the hydralic tentioners seam to be doing the right thing
  • gidgi
    gidgi
    sorry Ando I`m not clued up with this ,are you saying because of slightly more crank run out you wouldn`t go gear drive ?
  • gidgi
    gidgi
    Good stuff guys ,I value your opions,  thanks for advice now I understand more about crank runout I have seen lots of posts about this but never really understood the importance...cheers
  • Ando
    Ando
    Yeh mate ya need to have less than .003" crank runout for GEARDRIVES
    All 103s I have opened have been over that limit, if you are lucky enough to have one .003" or under I would have no issues fitting the Geardrives, as even with the ones I have checked with over .003" runout and re checked later haven't moved and these are punching pretty good numbers and get flogged
    so to me welding crank aint even a must as long as runout is within spec
  • Cartoon Head
    Cartoon Head
    Yeah personally I would only fit gear drives if the crank was plugged and welded 1st, I hear what you are saying Ando but I'd forever be worried it was gonna detonate the motor.
    i like the gear drive system if the crank hastn't run out by now it should be ok , don't like the 1999 to 2006 model cam chest  , what do you guys do to improve this model cam chest ,  but then again i like old cast iron sportys all geardrive with solid tappets
    quite expensive set up to go from one chain to another  i dont think the cams are far enough apart not to have gear drive i would be defferent if the cams were 9 inches apart or 9 inches away from the crank like a high camer pushrod engine like a Vincent
    The advantage to gear drive cams is better timing that you wouldn't even notice. The downside is cost, risk and limited selection in cams for your 103. The consensus from a lot of smart blokes on here, in shops and in America is that you wouldnt bother with gear driven cams on a stock bottom end. Save some money and use chain driven cams.
  • gidgi
    gidgi
    yeah I have already got chain drive cams fitted was just interested in opinions thx all
    all Harleys have been gear drive since day one including Panhead  Shovelhead  Blockhead Evolution & all Sportsters  except Twincam , i am not a fan of the chain @ all each to there own
  • Will67
    Will67
    dont want to bust anyones bubble but welding cranks is a load of crap according to S&S proof is in video 2
    hi Hilly , plugging do you put a slight oversize inner plug in the end of the hollow crank pin to spread out the pin more into the flywheel is that what you mean by plugging the crank  , i am interested as i have a 1999 dyna , stock pistons & heads atm  88ci that i use as a racebike,  i think the crank pin is welded not sure untill i pull her apart in the new off season as i want too keep her 88ci atm , to see what i can do to a max-out 88ci dyna on the track,  so far 11.3 sec 1/4 times @ 116 mph , i have a spare crank that needs a rebuild also  i need some help with to lighten etc , i normaly do a radius & cracktest & shot peen conrod service on the early girls /models for other shops or race engines,  for  i want to have a 88 ci into the 10sec bracket stock c.c., any help would be good  thanks
  • Will67
    Will67
    If you look at the video the crank pins have been plugged!
    Just saying lol
    yes i seen the vid now , see i don't do bottom ends & never will i always leave this too whoever i can trust to do the best job i even take the customers bottom end there my self & pick it up as i do not trust the courier to be kind enough to the parcel box  even box up proper,     but i do concentrate on the rest of the engine & heads myself one person only. cheers fella's ,     i will see if i can have one of my children put up a pic of my 1999 dyna race bike in the dyna section, she was a stat right-off i got very cheap so she will always be a racebike now 88 ci only no big engine she is going to be the Cattledog - underdog @ the racetrack up against the bigger bangers
  • Will67
    Will67
    im just curious as to why someone would go to all the expense buy pulling down a motor to have there crank welded and plugged when yo can buy bullet proof cranks already assembled.
    not trying to start a shit fight everyones entitaled to there opinion. but im not sure how you can not beleive the video when its there in front of you.
    i have been running gear drive cams in my stock 96cube now for 15000ks still runs sweet and i flogg the clacka out of it :-)
    i am trying to build Australia's fastest Harley street bike in another project she is a FXR base 145ci S&S twincam  with twin S&S super D carb's , a lot of work & expence aiming for 200 hp & 190 ftlb ,   when we brought the disasemabled engine from S&S we sent the crank via Darkhourse for checking & stich welding , the amount of frame work we had to do to fit this motor in is a lot as this 145ci is 2" taller than a normal twincam she will be i hope the 1st street rego'ed Harley into the 9 sec in the 1/4 mile biggest street bike 2 377 c.c. big
