Brake line connections
  • 92Fatboy
    92Fatboy
    Im nearly finished putting apes on, last job is with regards to brakes i've got the line that connects into two banjo's question is do you recommend  thread tape or gasket glue on the connections or does the brake fluid eat it over time ?
    Hi. not to sure what you mean but if it is the bolt that goes through the banjo, it has a sealing washer on either side of the banjo and needs no thread tape or gasket goo when you tighten the bolt into housing.
    no nothing , it should have a tapered end on the male ends like the end of your bleed nipple and the female should be internal tapered
  • 92Fatboy
    92Fatboy
    Thanks for the replies , I'm finding the Zodiac stuff is turning out to be shit stuff over time but cheaper up front, might go and get some plumbing thread tape and give the thread a coating.
    sorry dave and fatboy but if use thread tape on brake fittings your off your heads your not fixing the laundry tape leak
    if it leaks theres a problem with the fitting sealing area of the tapered area so not sure how thread tape is going to fix that
  • Hound_Dog
    Hound_Dog
    As far as I know (NSW) all brake line fittings must be swaged to be compliant. You should only have a banjo bolt and thats it for fittings.
  • DocGreen
    DocGreen
    92Fatboy, as the other guys have said mate, the lines have a tapered seat where they join either a solid line or a banjo fitting - no thread tape or anything else used. If it still leaks, they are either incompatible fittings, ie different tapers, or damaged seating areas, or loose. The banjo fittings should use a washer either side of the banjo.
    If unsure mate, don't stuff around get someone experienced to sort it for you.
    DocGreen
