Primary Drain Plug Leak 2000 Heritage ADL
  • Duanneb
    Duanneb
    Hi, been doing changes etc on my heritage for years now and the drain plug on the primary has developed a leak. It's the old tapered style. Tried tape, various loktites, etc but still leaks. I gather I've pulled the thread and it's now stripped in the cover.
    I'm assuming the only solution is to get the primary cover re-threaded?
    any suggestions on who to take the primary cover to in Adelaide to get this work done?
    other suggestions?
    thanks in advance.
  • robots
    robots
    Hi,
    You sure its drain plug and not fluid coming down back of primary?
    Thanks.robots
  • Duanneb
    Duanneb
    Hi, yeh, definitely the plug. I've taken it in and out so many times trying to seal it, I can do it blindfolded.
    ive cleaned around it after rides to determine if it might have been from elsewhere.
    no suggestions for a local had shop?
  • Cartoon Head
    Cartoon Head
    I'm not in Adelaide but I would just take it to a good engineering works shop, it's only a thread.
    Along the lines of what robots said, are you 100% sure? I ask as I thought for awhile that my primary plug was leaking until I put my hand underneath and behind the inner primary case and realised that it was the Jack shaft seal that was leaking. Might be worth a look, it didn't leak much just a few drop's after getting back from a ride.
