Improving 2014 Harley Iron Forks
  • Loom
    Loom
    Hi,
    I'm taking apart my Iron forks to put some Intinimators and thought while I was at it maybe I should do the 'oldman' mod of putting dyna damper tubes and progressive springs. Does anyone know if this will work on a 2014 Iron - it seems to have 90mm travel like the 48. Is it worth doing?
    Any advice appreciated!
    Loom
  • animall
    animall
    Hi I did it on my 2012 iron with intimidators and race tech springs , such a huge difference and well worth doing , gives an extra 2" hight and wheel travel no more bottoming out
  • Loom
    Loom
    Thanks Animall, did you have to specify a fork spring length or is it just any sportster spring? Cheers! Loom
  • animall
    animall
    I just ordered the iron springs rated for my weight
  • Loom
    Loom
    Thanks Animall
