Online: Dragon Man
Fork Seals
  • Sparra
    Sparra
    I will soon be putting 2" over tubes in my 2010 Wideglide and thought I would do the seals while I have it apart...Are they all the same or are some better than others...
    Cheers...Sparra
    I know that Harp seals are cuter that leopard seals, i don't know about better. OOPS, wrong seals sorry.............
  • Sparra
    Sparra
    smileysmileysmiley
  • Daggs
    Daggs
    Hutch, it sounds like you may have blown a seal at some point!
  • 98fxstc
    98fxstc
    I use OEM seals
    Generally look for better quality or to save dollars with other parts but not worth it with seals
    Dont save big dollars and usually cant measure sizes for other manufacturer till disassembled
    Have genuine ready to put straight back in
    Look at him, how cute, I want one.............He is laughing at you Daggs!
    Coincedentally, I am changing some on sat and some head stem bearings with a mate on his heritage with GLH frame and trease cases. goes hard!
