HELP NEEDED
  • czarek
    czarek
    I took my missus for a ride yesterday and she left her mark on the exhaust pipe.
    I have a black, melted rubber from the heel of her boot on the pipe. Can anyone help me?
    I need advice on how to remove it without scratching the pipe. Help please.
    Thanks
  • Magilla
    Magilla
    You know whats coming..............just don't take her out again!
    I'd reckon heat the bike back up and wipe it of with a thick damp cloth
  • czarek
    czarek
    Yeah, I know Magilla and that's the price I'm willing to pay but I really need some advice how to remove it, otherwise I will have to buy a new pipe and thats about $300 to $400.
    I am hoping that the forum members will help me.
  • Soapbox2627
    Soapbox2627
    I use autosol, its a bit strong so don't use it often
    some guys say spray WD40 on then leave it a while then wipe it off
  • WhatTaxi
    WhatTaxi
    Razor blade when it's cold dose it for me
  • czarek
    czarek
    Thanks
    I'll try Taxi's method first as the bike is cold. Then I 'll try to heat it up and wipe it off.
    Hey Taxi, wont the blade scratch the pipe?
  • WhatTaxi
    WhatTaxi
    didnt scratch mine , keep it at a low angle
  • Gypsylady
    Gypsylady
    MEK works well. But keep it away from painted surfaces.
  • Peter
    Peter
    If you undo the buckle on her shoe it should come straight off her foot, and it won't scratch the pipe as long as she is sitting down away from the bike.
  • czarek
    czarek
    Big THANK YOU guys.
    I knew I can count on you.
    Thanks again
    Czarek
  • WhatTaxi
    WhatTaxi
    So you got it off , good , how ??
    hey Czarek... gotta be worth more than a few brownie points hey... just remeber to bring up the marks on the pipes whenever ya get in the shit with the misses
    btw.. hope the cleaning goes good. I just used lots of rubbing with that Stardust Eclat from Frasers.. hard work though
