Online: GeoffP, John.R
cleaning products
  • kensim
    kensim
    18 years ago
    i was reading on the US forum, people use windex and all sorts of things to clean there bikes ,in my opinion mr sheen is good for chrome .i am looking for a good polish for the paint work, what do u blokes use?
  • kingchops
    kingchops
    18 years ago
    I use the old Mr Sheen for chrome and paint. Wash with dishwashing liquid.
  • kingchops
    kingchops
    18 years ago
    Sounds like good stuff, do you know of any auto shops you can get it from or is it just through the contact above?
  • nobody
    nobody
    18 years ago
    I use both windex & Mr Sheen on the chrome.I use Meguires NTX to polish the paintwork,and Meguires ScratchX to take any small scratches or swirl marks out of the paint
    nobody
  • Nige085
    Nige085
    18 years ago
    I have found for me a good old hot wax car wash by hand and a chamois is the best! That way there's no scratching anything and your bike comes up like new!! On my alloy parts I use a cordless drill with a wollen duster attached bought from Wollies which brings the shine up to perfection without any elbow grease!! It takes all of 1 hour to bring the bike up to new again!!
  • stbobrhino
    stbobrhino
    18 years ago
    I'm lucky I don't have to worry about polishing paintwork, and although I love the look of chrome, I'm not big into spending all my time keeping it clean, BUT, I do recommend Californian Custom Purple metal polish and Meguiars NXT All Metal Polysh. they are both excellent in my opinion. I got heavy, dull pitting out of the triple trees after a week in the salt air along the southern coast. mate I was with used autosol and couldn't get anywhere near the shine and finish I acheived..
  • Thomo_Baca
    Thomo_Baca
    Never really had to worry about it much before on a bike, so what do you use to wash it that doesnt cause rust if you leave it? I have some stuff for the wheels that sprays on and hoses off, but what about the rest of it?
  • Tapey
    Tapey
    I used to use Mr Sheen but now i use Brite Shine and find it much better, i couldnt belive the difference. It is only $10.00 a tin and it lasts for ages.
  • Hoodaman
    Hoodaman
    The cleaning product i always use is called "the wife"
    Can you believe my spell checker higlighted it, I then googled the spelling and made sure it was the correct definition (in case there was more than one) and still fucking managed to spell it wrong when I typed it...
    You can't buy my level of dumb!
    Edit for spelling.
  • Tapey
    Tapey
    I have just been told that insect spray is really good for getting bugs off paint and chrome. This guy told me he uses it on his car and it works really well. Anyone tried it?
  • andij
    andij
    truck or boat wash ,rinse,blowvac ,calliforn creams and polishes,toch up chrome with windex,viola
  • stbobrhino
    stbobrhino
    I gave a another fella my bottle of CC Purple and jar of Meguiars to try and he was impressed to go and buy both... the Meguiars is excellent on the trees as it leaves a coating that seems to make getting the bugs and shit off easier, and is 'supposed' to help protect against salty air etc...... I hadn't cleaned/polished my bike since last summer, and forgot how good it looks when done........
  • Mungrel
    Mungrel
    Purple polish is a very good product.  Wipe on / wipe off.
    Not real cheap, but lasts a long time.  http://www.calcustom.com.au/
  • Thomo_Baca
    Thomo_Baca
    i used the Harley stuff they gave me at PS tonight but forgot the blower vac from work, so had to go for a ride afterwards instead
    Spend more time cleaning the bloody thing than riding it. Isnt there a mob in Adelaide that do bike detailing? Might have to get them out when its really bad. Too slack myself
  • Hoodaman
    Hoodaman
    Spuin ur in Adelaide Thomo the mrs does a magic job on bikes here in Sydney.....
  • Fleabags
    Fleabags
    Anybody used the genuine HD gear? Products any good?
    http://www.motorcyclistonline.com/gearbox/harley_davidson_cleaning_system/index.html
  • FXSTC 09
    FXSTC 09
    I've stumbled onto a polish that's really impressed me.
    I worked in the crash trade for many years and always liked the 3m product range but recently was recommended I try a different product called 'Juice' Speed Wax. It's a water based cream wax that can not only be used on paint but does just as good a job on shining up chrome as any metal polish I've used.
    Being water based it goes on AND buffs off alot easier than solvent based polishes and does a really nice job on my Vivid Black tins. Plus it has the added bonus of and convenience of doing the painted areas and chrome in one application.
  • graeme
    graeme
    been using windex on chrome for 10 years no rust and live by the sea
  • Flak88
    Flak88
    Live by the sea too and always use silicone spray after I wash bike. Makes it easier to get dirt stains off. Helps on non chrome parts.
